ok, I'm thinking about trying to push my front end 6" before warm wheel'n season.
here is what I've roughed out.
My arms will be roughly 45" long, using my exsisting mounts.
bulletproofsteering for my arms not the steering.
The race edition comes out to $121 a stick
the rock edition comes out to $151 a stick
http://bulletproofsteering.com/tubingspecs.html
Either one I would believe to be plenty strong for the application.
remove my C's and use a ballistic fab bracket.
http://www.ballisticfabrication.com/...ts_p_1184.html
ballistic 2.63 joints top and bottom of the arm. with the upper link attached to the arm and bracket using heims.
I would have to fabricate or buy a new track bar riser as the fram mount location will not change. I will run it on the rear side of the axle tube.
i think using the ballistic joint on the lower connection will give me the side to side flex that bushing dont.
I already have a 4x4 steering box (forward facing pitman arm)
what do the guru's think?
