Took a trip to WH yesterday, bought the 66-75 trac bar drop bracket, adjustable trac bar, 4 1/2 progressive front bump stops, and extended driver/passenger e-brake lines.
Got home excited by the fact that at the end of the day I would finally be able jump up and down on my new bouncy front end (love the WH 3.5" progressive coil springs) and get to the rear axle work finale ... not so much, as I probably did not explain what I had/needed properly to get the right parts.
1. the drop bracket holes did not line up by almost 1/4" (see pic below) forcing us to "egg out" the hole with a grinder to get the 3rd bolt in. Not sure if there is that much variance from Ford (appears stock, untouched prior) or if the part tolerance was the issue. Since the bracket requires a final weld (hope I can drive it safely to the shop on the 3 bolts and a tack weld?) should I ask the shop to repair this, or will the final weld strength make this a non-issue?
2. With the FW HP Dana 44, neither the stock (27 1/2") nor F150 (35 1/2") trac bars center the front axle properly. I bought the WH adjustable bar specifically to remedy this, but it just barely extends that far. 32 1/2" appears to be the sweet spot (trac bar length), but that pushes the WH inner bar well past the 3" safety margin suggested in the WH instructions. My thoughts are to call WFO and ask about making a custom adjustable bar (heim joint was suggested by buddy?) or seeing if WH has an extended version not listed in their manual. Suggestions to do this right, and try to stay in the same $$$ ballpark???
3. Drag Link - is it likely/unlikely that I will also need a different drag link once I finally get a trac bar properly fit?
I realize that anything on a 40+ year old rig is basically custom, but its really frustrating and costly to take two steps back, especially if its because I'm not providing the right details to get the right parts.
Much thanks for your help here!!!
