70 Bronco @ Newark PNP
  • 70 Bronco @ Newark PNP
    They advertised a 70 Bronco at Newark Pick N Pull. I rushed over there today to have a look at it. It is actually a 1980. They have mis-labeled their inventory list on their website. I did however score two inline fuel pumps, a low pressure inline pump and an electric tank switch for my build. They also have a 1966 F series truck there with a decent instrument cluster. It is set up for the idiot light on the Oil and Amp. The speedo is clean as well as the housing is spotless. It is not cut out for the amp and oil guages. If you're interested in it, I pulled it out and tucked it in the utility bed it has on the passenger side.
    Brad
    1969 Sport, 351 roller EFI, 4R70W, TEAM BLUE.
    Re: 70 Bronco @ Newark PNP
    They got me hook line and sinker. It shows on the yard on 3-16-2012. I went there that weekend and did not see it. The guy said it was in the tracker system but not out in the yard. I went back the following weekend to see it and same as before, I know now it is a myth.
      They marked the 80 as a 70 on the driver's rear fender. They got me too!
        PNP bastages
