Pictures of 66 lift gate
  • Pictures of 66 lift gate
    Just wondering if anyone has pictures of the handle & lock mechanism on the frontside, and one of the backside of the lift gate?
    Thanks
    Re: Pictures of 66 lift gate
    Guess I am out of luck, I am trying to find out what the outside handle looks like and what the hole is for on the inspection cover if you will that is on the inside of the lift gate. Hopefully someone will shed some light on it in the future.
      Are you talking about on the tailgate. I have two and will gladly photograph for you
        I am talking about the lift gate on the hard top.
          outside
          inside
            Originally posted by gddyap View Post
            outside
            inside
            Thanks for the pictures,
            Wonder why the handle rod sticks out on the inside, maybe for no reason or some type of lever that helps hold the lift gate closed tight when handle is closed.
              Not sure on the rod. For sure the Bronco is a '66. The top has had some work done to it to fix some rust and I assume it's the original top.
