Guess I am out of luck, I am trying to find out what the outside handle looks like and what the hole is for on the inspection cover if you will that is on the inside of the lift gate. Hopefully someone will shed some light on it in the future.
Thanks for the pictures,
Wonder why the handle rod sticks out on the inside, maybe for no reason or some type of lever that helps hold the lift gate closed tight when handle is closed.
