what is the going rate for 5.0 Cobra EFI sets? I know someone who has two sets in his garage. Uppers ,lowers and the computers. Maybe more.
5.0 Cobra EFI
Re: 5.0 Cobra EFI
Originally posted by kwspony View Postwhat is the going rate for 5.0 Cobra EFI sets? I know someone who has two sets in his garage. Uppers ,lowers and the computers. Maybe more.
ECUs - $100.00 and up2002 F250 Superduty, 7.3 241,500 miles and counting
Re: 5.0 Cobra EFI
so would a fair price be $600 for upper and lowers, computer and harness?1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
Re: 5.0 Cobra EFI
Karl, maybe my cheapness is showing but I'd say closer to $400. The manifold was good, better than the regular 89-93 Mustang 5.0 stuff, but not much better than the now widely available Explorer setup. The ECU is unique; it was intended for use with 24 lb injectors plus the larger Cobra throttle body and mass air meter. Back in the day, a lot of drag racers tossed that ECU in favor of the A9L, I believe because it was felt that some parts of the tune in the latter computer were better for racing. Doug can chime in here, since he's way more versed in that than I am. Still, it devalued the Cobra ECU since folks wanted to get rid of it.
That said, I think it's a great swap for a Bronco, as long as you get all the pieces and understand they need to work together. The extra margin that the 24 lb injectors give means you can squeeze the engine for more power without bumping up against the limit of the more-common 19 lb injectors. To go with bigger injectors using a standard Mustang 5.0 ECU (like I have) a chip is required.1970, Exploder 5.0 with P heads, EEC-IV EDIS, lots of wiring.
