Spring fever a little early for me..Took the soft top off! I hate having the top on..More ways then one
Replaced both turn signal and brake light harnesses, replaced the fuel tank gasket that was leaking and started installing the SD 709 air compressor for OBA. Looks like I will need to work on the pulley alignment some
72 Bronco, 89 5.0 EFI, NP435, Mustang Hydro, PSC Steering with Ram Assist, Dana 20 with Twin Sticks, Rear 9 inch with Detroit, Front Dana 44-Yukon Gold Joints with Detroit, 5.13 gears, 5.5" Coils up front, 4 Link rear with 2" body lift, 37" Toyos...Money Pit!
