I wanted to run my explorer brackets on my 94 ford bronco 5.8 but was wondering what do I do about my crankshaft pulley. Is there a doner vehicle that I can change pulleys with. The stock 5.8 has 4 bolts to take the pulley off. I just need to find a shallower pulley. Thanks Matt
94 5.8 with explorer brackets question
Re: 94 5.8 with explorer brackets question
Run a 28 oz modified Exploder balancer. Damper Dudes stocked them when I needed one.
WH also is reported to have kind of adapter doohickey, but I've never looked for it.Last edited by ntsqd; 01-03-2016, 02:12 PM.Cross-threaded is tighter than lock-tite
Thats an option to change my balancer but it would be easier just to change to a shallower pulley and cheaper. Has anyone done this?
Wild horses has a 3 bolt one but I need a 4 bolt. I see some on summit racing but not sure if they will work.Last edited by Rockbronco67; 01-03-2016, 02:52 PM.
have you looked at March and other accessory vendors?
OR (having not held one) would it be possible to just redrill the explorer pulley?
http://www.wildhorses4x4.com/product...bronco_pulleys
OR
I thought I read that Randy at driven auto has a conversion pulley?Last edited by plug ugly; 01-03-2016, 06:06 PM.
You could also get an aftermarket damper that has both the 3 and 4 bolt patterns drilled and tapped in it. That would probably be easier than tracking down just a crank pulleyLast edited by Efibroncoman; 01-04-2016, 03:23 AM.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
I called Damper Dude today and he wanted me to mill the face of the balancer which I think is crazy. It really shouldn't be this hard and it probably isn't. All I need is a pulley. So I think I am going to try my luck with summitracing and see if there 3 or 4 bolt pulley will work. Seems like the easiest and cheapest way. Don't really want to mess with the balancer if I don't have to.
So let me get this straight, the Explorer crank pulley has 3 bolt holes? And you need it to have 4 to fit the 28oz. 5.8L damper right? Are the two different dampers the same depth? If so, why not just drill a new set of holes in the Explorer pulley?SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
explorer balancer
http://www.rockauto.com/catalog/more...nid=754&jpid=0
http://www.rockauto.com/catalog/more...nid=754&jpid=2
bronco
http://www.rockauto.com/catalog/more...id=1063&jpid=0
http://www.rockauto.com/catalog/more...id=1063&jpid=2
was wondering if this would work with a 3 bolt pulley from wildhorses or driven.
My Exploder balancer has the grooves in the balancer, there is no separate pulley. There are three drilled holes for the balancer puller to work with. I got it from Damper Dudes by asking for a 28 oz version of the Exploder balancer. What I recall is right around $200 delivered.Last edited by ntsqd; 01-04-2016, 05:23 PM.Cross-threaded is tighter than lock-tite
Im thinking this with the WH pulley might be the ticket
http://www.summitracing.com/parts/su...ions/make/ford
here is a new 31 dollar water pump too
http://www.rockauto.com/catalog/more...nid=776&jpid=0Last edited by plug ugly; 01-06-2016, 06:55 AM.
did you figure anything out Matt? I need to do something. My pulley was hitting my panhard at full stuff, bent the panhard, and now the damper hits the axle truss. Im wondering if there is any room to save the explorer stuff.
