Can someone that is running the Wild Horses Ron Davis EFI Radiator measure how high it sits above the grill (not core support) for me? Thanks
Wild Horses Ron Davis Radiator Height?
Re: Wild Horses Ron Davis Radiator Height?
Without a level, it looks to be 3 3/8"'88 347 roller, Exploder EFI, WH Shorties, NP435, twin stick D-20 with Tera lows, 44 4:56's w/ARB chromos and CTMs, 9" Detroit, cust dash, wiring and STILL ALMOST "DONE"!...
that's the highest point with it mounted (engine side tank flange). I did modify my mounts in order to make room for my serp. set up. the radiator sits flush against my car support. Top stock mounts move to the grill sid of the support and the stock bottom mounts were done the same with some cutting. I don't recall moving the tank up or down....intentionally....'88 347 roller, Exploder EFI, WH Shorties, NP435, twin stick D-20 with Tera lows, 44 4:56's w/ARB chromos and CTMs, 9" Detroit, cust dash, wiring and STILL ALMOST "DONE"!...
