I'm looking to purchase a EB, and I would like to know what smog concerns I must be aware of. Am looking for a 70 to 77 model, just not sure what year needs what. Thanks in advance for any help. jf
EB smog requirements?
I believe anything 74 and older does not require any smog check. When you buy it you will simply register it. At least thats all I had to do for my 72. Let us know if you need more info then that. FM72EB, one-ton fab project that will never end
Yes, 74 and prior are smog exempt. 75 and up have a few items including evap canister, vacuume tubes, NOX kit (on some), and other misc items like the 2bbl carb, correct timing, ect. Best thing to do if you plan on getting a 75+ is take it to a smog station before you buy it and look it over with the tech. He'll have the manual with all of the requirements
Good Luck!!“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
75 Model year is also exempt.
The rolling exemption has been repealed, so under current law 76 & 77 will never be exempt, so I would just avoid those to avoid the headaches.
CA requirements on 76 Bronco:
ACL, thermostatic air cleaner (draws warm air from exhaust man.)
EVAP, fuel evaporative system
OC, oxidizing catalytic converter
FR, fill pipe restrictor
BP/EGR, pack pressure exhaust gas recirculation valve
AIS, air injection system. Not on federal with auto except hi alt Bronco
EVAP-VC, evaporative vapor canister
BP/EGR-BPS, EGR backpressure sensor
EFE, Early Fuel Evaporation
CA requirement on 77 Bronco:
PCV, positive crankcase ventilation
Michael74 5.0 Explorer EFI, 4R70W, AtlasII 3.8, Stock PS, PB, 3.5" susp./2" body lift, 35" Swampers.
I have a 74 I'll sell if your intrested .67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
74 Bronco ,some dents,not to bad could be cleaned up very easiley
302 holley 4bar.,edelb. man., MSD ign
435
20
front disk 44 w/4.56 l/s
rear bb9" 4.56 w/ detroit
4.5 BC Bronco coils
national springs rear ?
2" body lift
on board air W/tank
full cage
hard top
custom bumpers,rock sliders
dura lined int.
cd player
other items I can't think of right now
the engine and drive train are all strong,just needs a new tie rod and drag
tires are 2 new BFG all terr. 35x12.50 and 2 Dunlops 35x12.50 on chrome rims
I also have other tires on allum. if interested
thinking $6500.00
heading to the con this weekend, but lets talk
I'll try and get some picts at some point67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
