Been awhile since I've done some wiring, so here it goes.
I'm installing an air horn on my 2002 f250 and would like to control it through the steering wheel via a separate power switch. I'm pretty sure the stock horn activates when grounded (push button, completes ground circuit and goes honk). IF I use a SPST switch wouldn't I just have to splice the solenoid wire to the stock wire at the switch for the "on" position and then the stock wire would be connected to the "off" pole?
Dunno why my brain isn't working thru this, so I'm putting my head-scratching out there to the masses....![Twak](https://www.norcalbroncos.com/forum/core/images/smilies/twak.gif)
Sean
Sean
