What do you all do with your used antifreeze? My local city has a curbside pick up for used motor oil with my regular weekly garbage pick up, but I'm not sure what to do with the 5 gallons of used antifreeze that I have. Does any place recycle it? Do any of the Vato Zones, Napa, O'Reilleys take it?
Used Radiator Cooant
Re: Used Radiator Cooant
I have not asked the local stores. Each time I've had some I've also just happened to be making a run over to the main recycling center in San Jose.
Not going to be that good with my timing every time I'm sure, so I should be checking even more locally too.
PaulWild Horses 4-Wheel Drive
Here in Livermore we have a hazardous waste disposal facility, I believe it is run by the county. They take pretty much everything. I have taken all kinds of stuff there, paint, thinner, antifreeze etc. It is free for residents. I am sure there's something similar near you as well.1970 Bronco
Our county has monthly hazardous waste drop off events. Here's your list:
https://www.co.fresno.ca.us/home/showdocument?id=18129
