I'm looking into building a 3 link for the front of my bronco (44) that is mainly street driven. Did someone make a bracket that bolts to the c wedges so you could bolt up a heim or johnny joint?
c wedge brackets
c wedge brackets
67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
67 Camaro Lq4,built 200r4,Hotchkis suspension(work in progre$$)Tags: None
I dunno if anyone makes the part you're looking for but I would suggest grinding the wedges off and using link tabs instead. I think the play from the bushings coupled with the heims in the link setup might have negative consequences. Plus it will look a lot cleaner. JMO...
Dusty
Thanks Dusty, I didn't even think about having double bushings at the axle end.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
But the CAGE arms use a bushing between the C-clamp and the arm. with c-bushings. couldnt be any worse than that and they seem to work... just my .02 POPS72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
ALL MY DRINKING BUDDIES HAVE A SEVERE BRONCO PROBLEM !!!
Originally posted by 71BRONCO71BULLSHIT! I love your meat in my mouth
Use link tabs One of the plus's of the 3 link is to dump the C bushings.
I used the 1 1/4 heims on the lowers, and 3/4 rod ends with step downs to 5/8 on the upper.
Doing it again, I would of done bushings on one end of the lowers, but I already had the heims.Mark Harris
