What is the cut off for ca smog? Also, do you have to have an initial smog done when you first register?
Ca smog/reg question
Originally posted by 68Steed View PostCorrect, 75 and older do not require smog inspections. But, you can still get tickets for not having the smog equipment.
Luke
I've lived in California most of my life, and have only seen one instance of roadside smog check.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
vehicle inspection
I saw it one time and got stopped in Modesto @tully ave. and standiford ave about four years ago. Thank god I was in my truck notmy bronco!73 bronco 351,nv4500,stk3spd,4.88,hp60f&r,detroit,arb,o/b air,welder,etc.
77,351 mass air efi ,nv4500 atlas 3.8 4.88,detroit31 spline,arb44 o/b air5.5 lift etc.
70 4.5 lift 351 c-4 d20 big bearing in progress.
Originally posted by Luke View PostI've lived here all my life and have never seen it. Not even once.
Most early broncos have it pretty easy with "required" smog equipment - as Catalytic converters and air injection were implemented in force pretty late in the EB production run. I'm not saying I want to have to deal with smogging a 38 year old vehicle... but I'll do it if I have to.Last edited by CityHick; 08-19-2008, 05:15 PM.1970 Bronco
New test in the bay area; in addition to testing the gas cap they place the fuel tank under minor pressure to see if there are leaks in your EVAP system. I have not had it done yet, but there was a thread on Classic about it...2002 F250 Superduty, 7.3 241,500 miles and counting
