tube measurements for tie rod/drag link
  • tube measurements for tie rod/drag link
    It seems the tie rod setup I bought years ago is too long. must have been for the full width front end. Anyone either:
    1 want to trade sets
    2 have a few new bungs they want to sell so I can cut mine down or
    3 give me the tube measurements so I can order a new set
    I already have the chevy 1 ton ends, just need a shorter set of tubes.
    Re: tube measurements for tie rod/drag link
    When mine were made I had too measure and send that in and they were made to spec. Call me and I can give you my specs, at home now....
    R-
      All I actually need is a 7/8 18 tbi weld in bung. Either side is fine.
        Gave me a reason to go touch mine so here ya go irregardless.
        25" from the drop pitman arm to the T and 38" between the TRE's. Mine are tapped for the TRE. 5.5" lift.
          If you would rather tap the tubing then weld in inserts I would be willing to help out, I have the 7/8-18 left and right taps. You could measure my ends to determine if they are the same as what you want and then go from there. I might even have some 1 3/8" o.d. x .250" i.d. tube that I could sell to you, its chromo too!
          Justin
          1969 EB, 88 Speed density EFI 302, HP D44 front w/ARB, Radius arm long arm, NP435, D20, D60 w/power lock rear, 4link rear with 4" stretch, Front and rear bumpers made by me.
            I originally bought my tie rod kit from seven rivers, and found out later that Parts Mike in Auburn sells everything and keeps it in stock to build the tie rod/ drag link set-up. He has different lengths of DOM, 1 ton tie rod ends, tube adapters and jam nuts, and much much more.
              X2 for a GREAT source and guy to buy from!
                Parts Mike is great and local. My set-up came from Scott at Rockstomper
                  where can I get a bung today? I think Parts Mike is closed on weekends. Any other local places?
                    AA Fab? Fishmouth? Silly? .....
                      do you have Adam's #?
                        Why not cut the old bung out. thats what we did when we shortend justins track bar. cut the weld and weld it back in...
                          turns out my tubing is odd. I cut it down and can not shorten it with what I have. Besides, I got the wrong ends from AA Fab. I just ordered a new tie rod from Adam and will pick it up Monday.
                            Sorry you couldnt get er done yesterday, but at least your on track
                              yeah, it will eventually get done. thanks for the help.
