Will this 351W oil pan work in my old Bronco, or will the diff get into it? It came off of the engine that was in a 1992 F-250 4x4 with TTB front axle.
Correct 351W oil pan?
Re: Correct 351W oil pan?
I don't plan on catching air, but it could happen. I'll have to come check out your bronco since you have stretched it. I might move my front axle forward a little more.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
I think you're probably ok with that pan. I run the pan that was designed for swapping a 351w into a fox body mustang and it works pretty well. I could see it being a problem if I ever jumped the Bronco and didn't have bumpstops, but I've flexed my rig pretty well and never had any interference problems at all.1970 Bronco
