Nothing worse than leaving a big grease stain behind you..so i got a new gasket for my 9" rearend...it will be my first major adventure on my EB..should I just replace the gasket and oil or should i bite the bullet and rebuild the whole the thing from axle to axle (excluding the thrid member). I am happy with the gearing and it is the original A3 rear axle.
my rearend leaks
Re: my rearend leaks
I've never use the gaskets. Just use some quality rtv.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
