I am in the process of restoring my '68 Ford Bronco and need to make room for more parts. The following is what I have available and the only parts I have available at this time:
- RAT 3-speed with Duff floor shifter, clutch plate, dust cover, etc... (Worked fine when I took it out to swap in the AOD): $250 obo
- Dana 20 Transfer Case with Duff shifter (Worked fine when I took it out to swap in NP205): $250 obo ($400 for 3-speed and Dana 20 together)
- Early Bronco Radiator (Used Condition & may be original since was on my Bronco when I bought it): $65 obo
- Early Bronco Steering Column w/ Steering Wheel (Used Condition: Steering Wheel is cracked and previous owner crudely cut-off 3-on-the-tree shifter & linkage): $75 obo
- Edelbrock 1405 4-Barrel Carb (Worked great, but switched back to two (2) barrel carb): $75 obo
- Rochester Q-Jet 1524 4-Barrel Carb (Worked when removed from Chevy 350, but went another direction with project): $200 obo
- BW 1345 Transfer Case (Worked when removed from 1986 Fullsize Bronco): $125 obo
- Oversized Yokes from NP205 (Possibly 28 Spline 1350, but please verify, since I only know that they are bigger than 1310): $50 each or $90 for the pair
See pics of items here: http://www.flickr.com/photos/2580917...7621817225362/
Local pick-up and serious bidders only. Otherwise, I'm fine if you know someone in this area who may be coming to your area.
Thanks,
Brian
(408) 673-1699
Thanks,
Brian
(408) 673-1699
