Bronco/Versailles rear disc components $50
  • Bronco/Versailles rear disc components $50
    Lincoln Versailles back shields, caliper brackets and calipers w/ebrake. The calipers are for rebuild or core and brackets need to be pressed off the axles. $50 or $40 donation to NCB. Do your research. Some say not so hot for crawlers. Changing an axle in the field would be interesting.
    Just a stock 1966 U13, 170 ci 6 cyl, no kiddin'.
    Re: Bronco/Versailles rear disc components $50
    Do you know if the Versailles calipers are the same as the MK II? Do you have all the ebrake parts and pieces on those calipers?
    '88 347 roller, Exploder EFI, WH Shorties, NP435, twin stick D-20 with Tera lows, 44 4:56's w/ARB chromos and CTMs, 9" Detroit, cust dash, wiring and STILL ALMOST "DONE"!...
      Not sure on the MKII. The ebrake is simple, just a lever and whatever is inside. Here are some close ups.
        PM Sent
