Carburetor/ignition stuff
  • Carburetor/ignition stuff
    Help me fund my EFI conversion
    Up for sale are the following items (and there will likely be more). All prices negotiable.
    Ford Motorsport 351w dual-plane 4bbl aluminum intake manifold. $50
    Ford Duraspark distributor for 351w. Cast iron drive gear. $50 SOLD to earlybronco72
    BC Broncos Qjet to square bore adapter with insulated base gaskets. $10
    Brand new Summit branded mechanical fuel pump. Rebuildable. $30
    Very low mile used mechanical fuel pump. Take it as a trail spare. $beer
    Chrome PCV breather. $beer
    Factory throttle bellcrank linkage. $beer
    14" round chrome drop base edelbrock air cleaner for 4bbl carb. $beer
    Located in Livermore, prefer not to ship but can deliver to Elk Grove and South Bay.
    Thanks for looking!
    Tony
    Re: Carburetor/ignition stuff
    Tony, does the dissy come with the module and harness? I could use this and will take the distributor no matter what.
      Marc, I converted it over to use a GM HEI module and thus there is no "ford" connector left on it, it's a 4 pin weatherpack. I'd be happy to supply my homemade harness and a module with it if you want that as well. It works well. It will still run with a duraspark module as well, only thing missing is that connector.
      I am in Elk Grove once every month or two. Next planned trip is mid February.
        Cool. Let me know next time your up here and I will take it.
          This stuff would go perfect with the 351w I have for sale.
          Bump for a great deal
            If I'd have thought about it, I could have sent it up last night with my parents. Oh well, this might give me an excuse to check out that buggy project of yours.
              Bump... emphasis on the OBO prices. I'm very flexible for NCBers. If nobody bites here, then it'll all hit Craigslist.
              Also have a 14" round chrome edelbrock air cleaner - the drop-base type. Fits standard 4bbl carbs. Comes with an almost new 2" filter element. Fits under stock hood with 2" BL.
                How much for the air cleaner thanks
                  What's it worth to you? I listed it as $beer above... not sure what to charge. I think it was $40-50 originally and its been used. $15 maybe? 3-4 bottles of Pliny The Elder would also work. Shoot me an offer.
