T-shift Dana 20
  • T-shift Dana 20
    Looking for a Dana 20. Anyone around the Sacramento area have one they are looking to part with?
    Re: T-shift Dana 20
    Did you blow yours up?
      Re: T-shift Dana 20
      Nope. It has always had an issue of not going all the way into 4hi, and I want to clock it up, which involves drilling new mounting holes, tapping them and then welding nuts to the inside to increase the depth of the threads. I just figures it would be nice to modify another and still have this one as a working unit as a spare.
        Re: T-shift Dana 20
        Would just a case work ? And how would we know a T from a J if we only had the case.
          Re: T-shift Dana 20
          I'm not sure how you tell the difference between the cases. I would prefer a complete t-case so I can keep this one as a spare.
            Re: T-shift Dana 20
            The simple answer is the shift rods are different... T-case has a removable metal bracket tying the two rods together at the end.
            Here is a picture of a J-case
              Re: T-shift Dana 20
              Thanks Doug, but what if the case is empty.
                Re: T-shift Dana 20
                Marc, got a few anchors sitting around here
                  Re: T-shift Dana 20
                  We will have to get together then. Are you available today after three?
                    Re: T-shift Dana 20
                    Rick hooked me up, and I got what I need. Now to find time.
                      Re: T-shift Dana 20
                      Luckily Dana 20's are small... Take it inside for the teardown while watchng the game... The kid can help, or watch...
                        Re: T-shift Dana 20
                        Josh would
                          Re: T-shift Dana 20
                          I should have, but instead I cooked the boy dinner. I think he liked my choice. Not a big hurry, just want it done before I got I Moab at the end if April.
                            Re: T-shift Dana 20
                            I have a clocking ring made, from what I remember it needed a spacer or something made on the input shaft. I never did and drilled the case.
