I picked this up with a bunch of other parts from a guy getting out of the Bronco scene. Lots of work went into this, everything TIG welded and pretty clean. Narrowed 8" with molded fender openings and metal door fillers. All body mounts have been relocated to fit a stock bronco frame and there are tube steel rocker supports that make the tub very solid. If nobody wants it, I'll probably cut the back half off for a sweet Bronco trailer. What you see in the pictures is what you get. going to need body filler work redone in the door areas due to cracking, but the body lines are nice and straight. It's on my trailer now and I'll deliver to someone local.
Jim (916)416-8397
Please buy this and save me from doing something really expensive!
Jim (916)416-8397
