Well since the build is complete I guess it is time to part with the leftovers. Most everything here was run for one season and had limited use. The plan is to make a run up north with what everyone has purchased. The final destination will be Manteca but I can make a few stops along the way to hit anyone between here and there. Here is a short list. There are more details on the attached. PM me if interested and for pics and I will try to turn around quickly.
Pitbull radial rockers 37" - $1200
Raceline Monsters 17" - $1200
Front Dana 44. 4.56 Air locker, chromoly axles, disc brakes, and more - $2000
Rear 9" - 4.56 31 spline, Yukon axles, disc brakes, and more - $1500
Stock rear shafts - $100
Stock radius arms - $150
DOM tube bent for extended radius arms (Lars bars) NEW - $100
Synergy frame joint mounts, NEW - $50
Ballistic adjustable coil mounts NEW - $95
Ballistic coil perches NEW - $35
Ballistic adjustable coil/shock mount combo NEW - $180
Dana 20 twin sticked w/ZF adapter - $300 *SOLD*
Dana 20 t shifters bent for ZF into stock location - $100 *SOLD*
JB Fab transfer case shift knobs - $20 *SOLD* DoubleXL
Deaver front 4.5" Springs - $125
Deaver rear leaf packs 3.5" - $300
4X4X2 Steering box - $300
Bullet proof steering - $150 *SOLD* jperry1290
Adjustable track bar - $150
Corbeau Rear Sear - $300
Drive Shafts (2)- $100 ea
Fuel Rail for EFI - $50
Electric Windshield Wiper Motor - $15, Linkage $10
23 Gallon Fuel Tank FREE - SOLD to rose916
7* radius arm bushings - $15
BC Broncos Fuel Accumulator - $40 *SOLD*
Dana 60 front truss and diff cover - $300
Dana 70 rear truss and diff cover - $200
Antiwrap bar - $75
Drop Pitman Arm - $25
**New Items**
1.5" Wheel spacers 5X5.5 - $40
2" Wheel spacers 5X5.5 - $40
Magnaflow mufler 2.5" inlet/outlet - $50
Warn premium hub inner splined hub saved for spare- $10
Battery tray, was new when put in 2 years ago - $10
Stainless braded front brake lines to caliper - $40
Stock Dana 60 king pin knuckles - $50
**Found some more **
15X10 5x5.5 wheels - $40
15X8 5X5.5 wheel $10
Gorilla Warlares used - $40 SOLD - earlybronco72
Radiator overflow tank - $5
Antiwrap bar - $75
**New Items**
