Does anyone have a GM TRE reamer that I can rent? I've got 2 knuckles that I need to ream. Thanks.
GM TRE Reamer
Re: GM TRE Reamer
Originally posted by 75BRNCO View Posthttp://www.ruffstuffspecialties.com/...STEER-2PK.html
Try these, they work great. And you don't need a reamerMarc D.
Re: GM TRE Reamer
Originally posted by crawlin68 View PostI don't have a 7/8 drill bit either.Originally posted by TBS-POPSAfter a huge amount of reflection, I have determined that what I saw in ukiah was in fact Brians bronco. I was also informed by my wife that she infact heard it run!!
Re: GM TRE Reamer
Originally posted by crawlin68 View PostI don't have a 7/8 drill bit either.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Re: GM TRE Reamer
Bronco Brian's mail order tool loaner program works again!1970 Bronco
Re: GM TRE Reamer
Originally posted by CityHick View PostBronco Brian's mail order tool loaner program works again!Originally posted by TBS-POPSAfter a huge amount of reflection, I have determined that what I saw in ukiah was in fact Brians bronco. I was also informed by my wife that she infact heard it run!!
Re: GM TRE Reamer
So I assume I am not telling you anything you don't already know, but if you are reaming to go tie-rod over on 1978-79 bronco knuckles (or 1976-79 f-150) you might end up having trouble with "hour glassing" the knuckles because the original taper is much larger than on the early bronco ones. I ran into this trouble when I used F-150 knuckles, ended up going the Ruff Stuff insert way.
