Anyone have one laying around that they changed their mind on? Or maybe want a different ratio? I am looking for a Atlas 5.0 with a 29spline input. If not I will be ordering one next holiday sale. Thanks Matt
WTB Atlas 5.0
Re: WTB Atlas 5.0
Why? 150:1 is not low enough? My last setup I was at 177:1 at lowest and I would barely ever use it, although nice to have.Last edited by Rockbronco67; 11-06-2015, 03:14 PM.
Re: WTB Atlas 5.0
I'm at 126:1 and it's plenty low enough for me. More torque lessens the need for lower gears too. But often in granny- low I can't get enough wheel speed and have to up shift to first gear.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Re: WTB Atlas 5.0
Originally posted by plug ugly View Postwhat abut go fast tho?SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Re: WTB Atlas 5.0
have you pushed through the desert at 40 to 60 mph? Street and street pressures are a lot different. A hard packed run out committee is much different than pushing through soft, silt. Plus, and part of my search for a better tranny set up, is the bad shifts and the serious slow down especially between 3/4. I doubt a zf and nv are too different.Last edited by plug ugly; 11-06-2015, 06:26 PM.
Re: WTB Atlas 5.0
Not yet, but I'm not crazy about sand. I'd like to go to the unevent someday but that's a lot more scenic than Johnson Valley. Don't have any urge to see the Hammers.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Re: WTB Atlas 5.0
Originally posted by Efibroncoman View PostNot yet, but I'm not crazy about sand. I'd like to go to the unevent someday but that's a lot more scenic than Johnson Valley. Don't have any urge to see the Hammers.
Mat driving in high range will suck in jv type situations otherwise mo powaaaa needed with the 351w. I could be talking out off my ass though cause mine only has 99hp if I'm lucky, so I need a 2-1 for my "high range"Last edited by bent70; 11-07-2015, 06:55 AM.70 eb 60f 14b mild 302 435-klune 4-1-np205 and some dents
Re: WTB Atlas 5.0
I also don't have sway bars and driving over 40 mph off-road would be really sketchy! If I ever have the urge to do that, I'll build a desert truck not attempt to do it in a rock crawler...SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Re: WTB Atlas 5.0
I'm off the 5.0. Will be looking at the 3.8 or 4.3. I spoke with AA and they basically talked me out of the 5.0. Told me like most of you said, the 5.0 is more for 4 and 6cylinders. It has the smallest and weakest gear set of the Atlas 2. Although would meet most of my wheelin ratios. Maybe go bigger on my Ring and Pinion.
