More used Bronco/Ford stuff in one place than you can shake a stick at! Oct 15th
  • More used Bronco/Ford stuff in one place than you can shake a stick at! Oct 15th
    That's right we're going to have sheet metal, suspension, cooling, fuel tanks, trim, just about anything you can think of and that's just the WH parts. Over 30 people are bring parts for sale. Last year we filled the parking lot (2 acres). Sign up and clean out your garage! Music, food truck and lots of Broncos. Looking for a Bronco? We have 5-10 that say they are bringing rigs for sale. Hope to see you at WILD HORSES on the 15th.
    Jim
    Re: More used Bronco/Ford stuff in one place than you can shake a stick at! Oct 15th
ID:	274284just started loading!
      Originally posted by camp9k View Post
      [ATTACH=CONFIG]30665[/ATTACH]just started loading!
      what are you asking for that tailgate?
        It for Justin at WH unless he passes on it...no rust but missing some hardware...its $100 to him or you if he passes on it.
          If he passes on it....I'll take it
            i will let you look at it and decide...your next in line but no commitment to buy...its what I paid for it...see you there!
              Ok Folks, here is a preview of my Junk...
              I am not trying to get rich here, just clearing space in my garage.
              Prices are $1 to $20, except for the D20 J-shift, which I would like $100 bucks for. PO made a mod to the shift rail and I have a replacement rail
              This stuff came from my 68, 71, 75, and 77 broncos...
              Random info, respond if you have a specific question... 71 Manual steering box, 86 5.0 flex plate (50oz imbalance), 68 heater duct > has small tear in it, new sand flag, T-shifter covers > one is good shape and the others is for parts, 77 valve covers with Fed emission sticker, new 2-spd wiper switch, new headlight switch with no spacer, used headlight switch, two used ign switches, used Warn hubs > body longer on one, stock clutch rod, one clutch rod with spacer, 3 small brake petals, fresh air duct door, drum brake spindles> D44, used fuel pump, new starter Mo-craft relay, stock trans cross-member with brackets, 77 proportioning valve with bracket, 77 off-set bracket brake bell crank, two heater fans with metal fan drum > both work, one squeaks, working horn, mounting brackets/harware for 71 rear tank.
ID:	274285Click image for larger version
ID:	274296Click image for larger version
ID:	274297Click image for larger version
ID:	274298Click image for larger version
ID:	274299Click image for larger version
ID:	274300Click image for larger version
ID:	274301Click image for larger version
ID:	274302Click image for larger version
ID:	274303Click image for larger version
ID:	274295Click image for larger version
ID:	274294Click image for larger version
ID:	274286Click image for larger version
ID:	274287Click image for larger version
ID:	274288Click image for larger version
ID:	274289Click image for larger version
ID:	274290Click image for larger version
ID:	274291Click image for larger version
ID:	274292Click image for larger version
ID:	274293Click image for larger version
ID:	274304Click image for larger version
ID:	274313Click image for larger version
ID:	274310Click image for larger version
ID:	274306Click image for larger version
ID:	274314Click image for larger version
ID:	274311Click image for larger version
ID:	274305Click image for larger version
ID:	274308Click image for larger version
ID:	274312Click image for larger version
ID:	274309Click image for larger version
                I can use the cross member and brackets and if one of those pedals is the wider brake pedal 76/77 version.
                  I cannot make it to WH this weekend, but if the steering stabilizer brackets are still available after the show, I'll take them. Flat rate USPS box should do it...
                    Originally posted by bronken View Post
                    i can use the cross member and brackets and if one of those pedals is the wider brake pedal 76/77 version.
                    sold
                    But it is a no on the large pedal, all three are small pad.
                      So Tony, the three brackets are the tie rod end ones... 2 of one style and one of the other. Which ones are you interested in?
                      Still working in South SJ? I could do a drive buy... Doug
                        So it looks like the: jack, jack strap, jack crank handle, the Better of the two T-shift covers, Manual Steering box, and (possibly the EFI distributor) are all spoken for.
                        Doug
                        Sold
                          Clutch pedal and std bell housing needed
                            I have a pedal, new pad, and spacer... I have the plate behind the flywheel, but not the bell housing...
                              Looks like we have good swap meet weather. Hope to see you all here.
                              Jim
