I want to add ram assist to the 79. Anybody have some parts they want to sell?
Look for ram assist steering
Re: Look for ram assist steering
I have a WTO 1.5" dia, 8" stroke ram with a slightly bent shaft you can have. You might be able to straighten it in a press. No rod ends for it. I also have a piece of delrin shaft to make a travel spacer if 8" is too much (said no woman ever). They put a bunch of flat washers in it to limit travel but they can scratch the shaft. I replaced it with a PSC ram because WTO said they don't sell replacement shafts and if I had to buy a new ram anyway I got one that I could get replacement shafts for.
I also have a clamp for a 1.25" OD tie rod with a couple of tabs welded to it. $20.
I have a PSC 1.75" x 8" single ended ram with a bent shaft. The original kit was $185 and I think a new shaft and seal kit would cost $60. I also have a 1.5" ID clamp so toe-in is always adjustable.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Originally posted by Efibroncoman View PostI have a PSC 1.75" x 8" single ended ram with a bent shaft. The original kit was $185 and I think a new shaft and seal kit would cost $60. I also have a 1.5" ID clamp so toe-in is always adjustable.
Originally posted by crawlin68 View PostIs the body of the ram in good shape, just the shaft is bent? You don't happen to have a picture of do you?SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
PM'd youSOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
