used (about 3.5 years old) WH rock crawler coils, and the upper coil buckets.
The coil buckets have 2 1/2 holes drilled in the center as I bolted them to the frame.
Great for youe rear coil swap!
I will even give you the lower mounts as well, but they have gobs of weld that need to be ground down.
80$
80$
