Unfortunately the new bcb exhaust tubing to muffler will not fit the AOD setup so it is for sale . It is for the BCB slip fit header and is complete to the muffler. Asking 75.00. Tubing is 2.5". Thanks, CK
BCB slip fit exhaust tubing
Originally posted by Cowboy Ken View PostUnfortunately the new bcb exhaust tubing to muffler will not fit the AOD setup so it is for sale . It is for the BCB slip fit header and is complete to the muffler. Asking 75.00. Tubing is 2.5". Thanks, CK
If it hasn't been welded I might be interested. Please elaborate!
Thanks,
Tony1970 Bronco
This is tempting. I'll let you know...
I am assuming the pipes are not mandrel bent and probably either mild steel or aluminized tube?1970 Bronco
They are aluminized steel, not mandrel bent. BCB doesn't have a pic on their site just the dyno results with thier header/pipes/muffler combo. I will be back from work on Tuesday and send a pic. Remember you must have the BCB headers for the slip fit (no flange type). I just wish they fit my AOD but that extra length/width of trans got me. CK
As I do not yet have headers, if I buy your pipes I will pick up the slip fit BCB headers. I run a 351w with an NP435 behind it. I know headers are going to be tight - but as they are slip fit, it seems like I'll have some adjustment. Your location says Tracy - maybe sometime next week I can swing out your way and take a look? I will be passing through on 205 on Thursday or Friday.1970 Bronco
I'm going to pass for now. Too many other projects going at the moment. I need to mount my cage arms first and take some measurements. I'm kind of leaning towards a DIY system.1970 Bronco
