WTB Saginaw p.s. pump
  • WTB Saginaw p.s. pump
    I am looking for a Saginaw p.s. pump . Either Chevy or Ford. I also need the pump housing bracket and if it is a Ford pump I will also need the adjuster bracket.
    Stick with the saginaw if you can. The ford pumps are noisey!
    Did you find a box?
      Yes, I picked up a working 4 turn EB box for 200 bucks. So now I am in the market for the saginaw pump and some brackets. I am taking a trip to the wrecking yard soon to see about the brackets. I know where there might be a Ford econoline van with a 351 in it .
        you running a 351w?
          Got one from napa.... 65.00..... (havent put it on) The pump I am running now is from W/H and whined like a son o b!tch on the Rubicon..
          Sagnaw or whatever good luck...
          Aaron
          KK6DAD
            No , I am running a 302. But I know how to mod the 351 brackets. I will call napa on tuesday thanks.
              I have two pumps that i could not use. I pulled one off of a big block with both brackets.
              Heres the LINK
