Need a flywheel dust cover for my 302/C4 bellhousing. Anybody got one laying around?
Flywheel dust cover
Flywheel dust cover
And a bunch of other crap, some of them run.....Tags: None
Any chance its the same as a manual trans cover? the bolts are in the same place right? If so I've got one in Livermore.1970 Bronco
Do I need the inspection plate, or can I just take the cover off to inspect it?70 rebuilt 302, Edelbrock Performer intake and carb, C4, 20 w/aftermarket gears & HD output, D44 w/Power-lock, disks, 4:88, 9 in Detroit, PS, PB, winch, lights, rock bumpers, full cage, 3 1/2" WH lift, 2" body lift, IROK 37's, 23 gal tank
You would have to take the tranny off to do that. The plate is there to make it easier from what I understand. In all the years I had an auto I never inspected anything through that plate.Vacaville, Ca
The inspection plate is there to get the torque converter bolts off or onto the flexplate...or drain the fluid out of the same IF so equipped... manual trans - no insp plate...solid flywheel. class is over72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
Originally posted by TBS-POPS View PostThe inspection plate is there to get the torque converter bolts off or onto the flexplate...or drain the fluid out of the same IF so equipped... manual trans - no insp plate...solid flywheel. class is overMarc D.
Thanks. So it's the "inspection plate" I am after, anybody got one laying around?70 rebuilt 302, Edelbrock Performer intake and carb, C4, 20 w/aftermarket gears & HD output, D44 w/Power-lock, disks, 4:88, 9 in Detroit, PS, PB, winch, lights, rock bumpers, full cage, 3 1/2" WH lift, 2" body lift, IROK 37's, 23 gal tank
There is an intermediate plate that goes between the engine and trans. the inspection plate attaches to that. you need both pieces if you dont have them..72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
I just need to sheet metal "inspection plate" to cover up the exposed flywheel.70 rebuilt 302, Edelbrock Performer intake and carb, C4, 20 w/aftermarket gears & HD output, D44 w/Power-lock, disks, 4:88, 9 in Detroit, PS, PB, winch, lights, rock bumpers, full cage, 3 1/2" WH lift, 2" body lift, IROK 37's, 23 gal tank
