Wanted - Air Injection tube
  • Wanted - Air Injection tube
    I need the air injection tube that goes from the air pump to the cat off a Late model Mustang 87 - 93, I figured most of you guys probably toss those things, but maybe someone has one...
    Doug
    Re: Wanted - Air Injection tube
    uhhhh.... I have no idea what that looks like but I have pretty much all the parts I took off my 89 5.0, maybe you can let me know a description and I can take a look.
    Kyle
      Kyle
      Well, I do not have a picture but... Two discharge hoses out of the air injection pump on the Pass side of the motor, upper one went to the air injection tube attached to the back of the heads...
      Lower one had a crimped on check valve and the tube went down to the cats, split in two, one to each cat. On an unmolested motor that still had the lifting brackets on the stock headers, the injection tube had a small "L" bracket that mounted to the lifting bracket... Hope that is a enough...
      Thx, Doug
        Ohhh I know what you are talking about. When I get home from work I will dig through my pile of mustang stuff and make sure I still have it. I believe I do even with the air pump.
        Kyle
          Kyle
          Copy That... I will check the site tonight...
            It will be tough to get those pipes up to the fittings, firewall clearance. I was worried about clearance when I hacked the ends and welded them shut..... Fit though
              I know what your talking about too. My donor mustang carcass went away last Saturday, but I'll check my pile as well. If this is the one I'm thinking of, it was like an inch in diameter. It may be possible to fab something up too.
                Thanks everyone for looking... I did this before on my 75 EB, so I have some experience in making things fit... I basically need a down pipe section and can fab up what I need from there...
                  Hey check out the picture and let me know what you want. I believe this is it, if there is more then let me know and I will keep digging.
                  Kyle
                    Kyle
                    I need the pipe in the middle... Want do you want for it?
                      Throw a few bucks my way for shipping. I dont know how much it will be, I will grab it and bring it down to work tomorrow and go to the post office. Can't be hardly anything. Unless you are coming up my way anytime soon.
                      Let me know.
                      Kyle
                        Let me know.
                        Kyle
                        No road trips planned to God's country in the near future... Tell me an address for snail mail or paypal and I can send some $$ your way. Thanks.
                        Doug Conn
                        780 Easy Street
                        Morgan Hill, CA 95037-6212
                        408-489-5767 cell
                          Not a problem, I will call you tomorrow when I am at the post office.
                          Kyle
                            Kyle
                            Thanks for the call today Kyle...
