Power brake bracket wanted
  • Power brake bracket wanted
    Does anyone have anything for sale to get me started to upgrade to p/b for my 72.I just did a knuckle out swap with a 79 f150 with discs and want to drive it but not with the stock master cyl.
    Barry
    Re: Power brake bracket wanted
    I drove mine w/o power after I converted to front discs and it worked fine. Just took a little more pressure for faster stops.. didnt feel unsafe at all. actually was disapointed alittle with power booster at first but makes things easier to hold on the trail and rocks...
      Thanks for the reply.I`m going to try just what you said.Did you use the drum m/c or a disc m/c with prop valve?
      Barry
        Just the stock m/c and divider block.. still havent changed to the prop valve to a disc/drum..works ok...
          Mines set up the same, works great!
            I ran my '69 for 2 years with Dana-44 discs up front, the stock drum MC and Wildhorses disc/ drum prop valve. Worked great and it was a vast improvement over stock drums up front. Going hydroboost now since I've got the drivetrain gutted anyway...
              I'd sell you my entire Power Brake Booster set up for $275 if you're still looking. It's the complete James Duff set-up. It has a new 1 1/8 bore master cylinder (just installed last month, cost me $170) that will be included.
              This is the kit that sells for $435 from James Duff.
              -Dylan
                Sure
                Barry 916-663-2585
                  Sorry man! I thought that I sent that message to you in a PM, and since I didn't get a response I figured you weren't interested. I just stumbbled across your addition to the thread today. I'll give you a call this evening, and I'll also PM you with my phone number.
                  Dylan
