I am in the process of setting up the same thing. There is a big write up on West Coast Broncos. I have bought everything and I am assembling the box at this point. All I have to do is adjust the sector shaft. Link below http://www.wcb4x4.com/tech/diyrockcrawler.shtml
1974EB 302v8, NP435, dana 20 twinstick, dana 44, 9 inch Detriot Locker's, 4.88 gears, front disk, Rockbox, wild horses 4.5 inch lift, 4 wheel Warn Full Floater, 35 Super Swamp Bogers.
cool. thanks a lot man.
that steering box will bolt to frame or have to do mods/drill holes sleeve, etc?
How much did everything cost you?
I am looking this route or buy a complete set from psc which is sold at poly performance.
i know that psc poison spyder custom is the best and that is what is ran on just about all crawlers, like in mags and that sort of thing.
I think I have $675. in to the compleat setup. I have the one ton tie rods and chrome molly 1.5" tube. http://completeoffroad.com/i-124127-...44-and-60.html
Wescoast DYI adapters and rebuild kit http://www.wcb4x4.com/mm5/merchant.m...uct_Code=20739
$79.00 in to Pick your part steering box to do the reverse steer. You will need the adapter it will not bolt on. If I was able to spend the cash on a new box I would but you will still need all the other parts too. It would cost about $1200.00 to do it all new or rebuilt. I feel I got Just as good in the end and saved $600.00
I will take some pictures and post later tonight or tomorrow. Got a rod run to go to and a lot of work to do. Welder comming this weekend too.
I have a stock EB box rebuilt and ported for hydro steer that I will be selling if you are interested. I have been running it with one tons and 40's for about 2 years. It is in good shape and has no leaks.
FM <><
