Listing for a friend Call the attached number Chris 707 - 228 - 8689
Located in windsor CA
Here are some pictures.
comes with tranny (t-18/np435) tailhousing adapter (old 3 speed adapter cut and re-welded 31 spline input)
Cold duck seems fine worked just fine, some funky welding and machining but from what i'vee seen on the internet on par with this style cut adn re-welded t-case. The bronco t-case that is attached works fine sitll has stock outputs. the cast iron at the shifter seal did crack away. never seemed to be an issue, seeped a little and prevented the seal from doing its job but since you probably have your own case this one is there for extra parts.
Nice setup gives you multiple options 2.46 low range or 6.05:2 when both are locked in. or if you have tear low gears and a HD output in your t-case already, bolt it up and you'll now have either the 2.46:1 low range using the CD and keeping the t-case in high, 3.15:1 low range with CD in high and the t-case in low or 7.49:1 ubber low when you need it by locking both into their low settings.
Just cleaned it up today, seems like everyone always paints their stuff to sell it problem is paint hides the truth. here it is for you to seem with your own eyes..$750 OBO with or without the T-case.
picture of the inside of the cold duck case
outside of the cold duck case
whole assembly
welded up tranny adapter
inside the dana 20 case
Chris
707 - 228 - 8689
whole assembly
Chris
707 - 228 - 8689
