Ok selling off my front axle, rear axle, 4.5WH coils, and 5.5" WH leaf springs. Gotta fund the insanity.
Dana 44: year 76/77 Geared 4.10possi, built by Bronco connection in 2007. New ball joint, gears, diff, brakes. Includes Diff Guard and WH Tie rod. Wheeled it probably 500 miles. Towed it a couple thousand.
$900
Rear axle: 69 Small bearing, Geared Posi 3.50 31 spline, Superior 31 spline axles. Has WH Wrap trap welded to it so that goes too. 3rd member is out of and 86 bronco 9" I'm using to go full width.
$450.00
USED 4.5" WH rock crawler coil springs Black $100
USED 5.5" WH Leaf springs with WH heavy duty U bolt kit shim. $225
F100 2wd steering box: works fine good spare or core: $50
Stock 302 PS pump and brackets works but needs cleanup $40
Trailer hitch: $60
One 3 legged dog been hit by a car 4 times goes by the name lucky $5K
I Live in the NO "Fresno" but I'm in Sac every month. Thanks
Any Questions Call me
Russ
916-769-3319
Thanks for playing.....Gods speed and use protection.
$900
$450.00
Trailer hitch: $60
Russ
916-769-3319
![Grinning Smiley 004](https://www.norcalbroncos.com/forum/core/images/smilies/grinning-smiley-004.gif)
