Just checking to see if anybody has 4 or 6 degree shims for the rear leafs they aren't using. My springs have settled and now need to be adjusted. Thanks
Patrick
We have time to cut them off and reweld them tonight.
If you're gonna do that, I have a set of Ruff Stuff anti-wrap leaf spring perches that can probably be re-welded on an axle. I also have the thick top plates.
