I converted over to duraspark today from points and when I hooked it up I fired it up and the starter stayed engaged and engine and starter wouldn't shut off until I disconnected the wire on the left of the starter solenoid. After some screwing around with the wires I got it to work properly by disconnecting the red wire to the control module. Seems like this should be hooked up. Does anyone have more information on this. It is a duraspark from a 77 I think.
Dura spark I
Re: Dura spark I
It runs the way it is, but maybe I should switch how I had the red and white wires hooked up. Blue grommet on both modules.Last edited by earlybronco72; 03-18-2012, 07:11 PM.Marc D.
Re: Dura spark I
I had the same problem and used this...Attached Files2002 F250 Superduty, 7.3 241,500 miles and counting
