I was digging around picknpull today and finally started digging up a fan and found there's two taurus fans...one a bit smaller. The bigger one might be too big for the stock EB 4 core rad or so it seemed. Which fan have you guys used and are you happy with it. I know one of them is like 2800 CFM and is two speed or something like that.
Taurus Fans...Two versions. Which?
Re: Taurus Fans...Two versions. Which?
I would suggest using a two speed Volvo fan from a mid 90's wagon... They're thinner and have a much bigger shroud!SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Originally posted by Efibroncoman View PostI would suggest using a two speed Volvo fan from a mid 90's wagon... They're thinner and have a much bigger shroud!
Anyone on this board ever tapped into a EFI computer to control the fan via the sensor inputs...? This sounds like a 'Lars world' question...
Its my understanding that the Mustang A9L computer has controls for a fan built into the programming. It would be cool to have the actual computer drive the fan.
I will be able to get into the computer and change just about anything because I will be using a "Moates quarter horse" tuner that essentially cracks the computer and lets you hook up a laptop to it. You can even do data logging with some additional software. It allows you to maximize all the performance upgrades you add and can even be controlled while driving the car. I'm a bit of an electronic geek. I like having toys that are not always necessary.Don't worry about it...its mostly glass...will be fine...
I went to the woods to live deliberately...
Carpe' Dium
I use the big taurus fan, but i think it has finally died from being in ghe elements for years. I may rob the contour fan off my mustang. It thinner and have dual 10" fans.70 eb 60f 14b mild 302 435-klune 4-1-np205 and some dents
With the Quarterhorse, you will be able to run the fan.1971 EB: 3.5" 4 link rear, wristed front, 2" body, 96 Explorer 5.0 EDIS EEC-IV, C6, Nissan PS, Hydroboost w/front disks, 4.88 9" w/spool, D44 w/ aussie locker, TRO, 37" MTRs
Originally posted by Filgas View PostWith the Quarterhorse, you will be able to run the fan.Don't worry about it...its mostly glass...will be fine...
Carpe' Dium
I'm using the DC Control two speed fan controller and it works great! Most of the time it will just turn on the low speed setting, but 10 degrees after that it'll kick on the high speed setting. My bronco runs around 180 all day long... Only time it gets warmer is when going up Icehouse road at 3500 rpms because I couldn't hold 4th.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Originally posted by NOTPRETTY View PostAnyone on this board ever tapped into a EFI computer to control the fan via the sensor inputs.. that the Mustang A9L computer has controls for a fan built into the programming..Last edited by Spaceburger; 03-27-2012, 06:07 PM.Relativity: Where ever you go, there you are.
I've just got a Moates chip because once set up I don't plan on messing with it. I already had my electric fan set up w/ thermostat and relay, so I just left it that way. In my research a few years ago, I read about using the mustang computer to run the fan. In the quarterhorse software, you will see settings for low and high speed fan. I don't remember which pins you will need to add to the harness for the fan though.1971 EB: 3.5" 4 link rear, wristed front, 2" body, 96 Explorer 5.0 EDIS EEC-IV, C6, Nissan PS, Hydroboost w/front disks, 4.88 9" w/spool, D44 w/ aussie locker, TRO, 37" MTRs
Originally posted by Filgas View PostI've just got a Moates ... I don't remember which pins you will need to add to the harness for the fan though.Relativity: Where ever you go, there you are.
Originally posted by Spaceburger View Postreally? Which wire energizes this off the ECU? I don't remember a signal wire dedicated to this output..???Don't worry about it...its mostly glass...will be fine...
Carpe' Dium
Looked back at my notes from when I was researching this. Pin 41 is for hi speed fan control. It goes to the fan relay ground pin. You can only control a 1 speed fan, and not all the EEC-IVs work. It is hit and miss with your ECM.1971 EB: 3.5" 4 link rear, wristed front, 2" body, 96 Explorer 5.0 EDIS EEC-IV, C6, Nissan PS, Hydroboost w/front disks, 4.88 9" w/spool, D44 w/ aussie locker, TRO, 37" MTRs
