I've slowly been adding more and more electrical components to my Bronco. I understand the fundamentals of wiring just fine. The problem I'm having is finding power sources. Up until now I've just been tapping into what ever power source I can find for example if I need a switched power source I've been tapping into the switched side of the coil or if I need a constant hot lead I've been tapping into whatever connection I can find that has constant hot and adding another tail off of that. THIS IS NOT THE RIGHT WAY TO DO IT!! I know that! But up until now I've only added a few things and it hasn't been an issue. Now I'm adding more stuff and it's just turning into a mess of connections and I need to know the best way to get a hot lead off of the battery and a switched lead off of the ignition. My fuse box is maxed out so picking up a new terminal there isn't an option. Pictures help me a lot if you have any to post. I did purchase a new 4 gang fuse block which should help with the maxed out fuse block but still doesn't address my power source issue.
Signed, electricly challenged
