Decided to change out my axle bearings today since I was changing third members. Thanks Jack. Those bearings were very stubborn. I drilled a hole in the retainer and then hit it with cold chissle to break it to remove it. I then rigged the axle in my 20 ton press and failed to press the bearing off even inducing vibration with a 4 lbs hammer while the strain was on the bearing. In the end I ended up using my 4.5" grinder with a cut off wheel and cut the outer race and bearing cage off. After that I cut into the inner race making sure not to hit the axle. Once I had a good groove in it I hit it with my cold chissle again and it broke and came right off. First axle took about two hours of F'in around, and second axle took 4 minutes. I sure hope someone will learn from my pain.
9" axle bearings
Re: 9" axle bearings
I have always just got the torch out and scarfed the bearings off. Carefully!!!72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
Originally posted by TBS-POPS View PostI have always just got the torch out and scarfed the bearings off. Carefully!!!“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
