I am using the hydroboost and master cylinder from a 2004 ford f-250. I am not sure which port on the master cylinder is for the front axle and which is for the rear. I would have thought it would be front for the front and rear for the rear (that is how I set it up) but the original bronco one was front/back and back/front. Does it matter since the master cylinder is for a disc/disc.
I have a f-250 with the same setup but I can't just follow the lines because it goes through the ABS system. Does anyone know which port I should plumb to the front and which to the back?
