Thought I'd share a couple pictures of the cage I started. Wife and kids were out of town so I took monday and tuesday off of work and spent 4 days and a little over 50 hours. This is my first cage so don't be too harsh. Everything is tacked in place and I need to finish the seat mounts, add the grab handles and misc, pull the dash off, remove the cage, finish weld and paint. I wanted to do something a little different, wasn't so sure about the rear of the cage at first but I think it's growing on me, we'll see once it's all finished
first cage pics
Re: first cage pics
Looks good! Definitely different but I like different, I'm not really into the 70's looking bronco cages. I would definitely add some gussets to all four corners just for added strength but it looks like it's coming along nice...SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Re: first cage pics
Thanks, I'm open to constructive criticism and can handle straight criticism. Went through the dash, which was a pain to get right with using a hoop for the a pillar but well worth the leg room and being able to suck it up close to the dash. Was hoping joining three tubes together at the corners would help add rigidity to the junction. Will look at putting gussets in the rear and possibly in the center and hoping the grab handles on the A pillar will act as a gusset of sorts
Re: first cage pics
WFO sells them for 6.5" round speakers. They look really nice. I have some made from MDF and fiberglass that sound good.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Re: first cage pics
there seems to be various different lengths and thicknesses of gussets from what looks like 18ga or so to 3/16" or 1/4" or tube gussets. I would think that anything you put in there as long as installed correctly would be a benefit, but I was thinking about on the four corners where the three tubes meet maybe taking some 1/8" or so and form it creating like a spiderweb tying the tubes together and I would think it would be enough as long as it extended out away from the joint enough-was thinking around 5" or so......man I need some dimple dies. The cans are pretty slick and could be welded to the back side of the B pillar acting as a gusset. gotta see if we have any large diameter pipe at work
Re: first cage pics
Look good! Do you have plenty of head room with that X bar over your head though? The bars going threw the dash looks great...you can tell you really took your time there. Coming together nice...keep up the good work.70 Bronco, 5.0, ARB front 44, Detroit 9in Rear, Dana 20 w/ Rock Eaters, NP435, Beadlocked 36X13.5 IROXS
Re: first cage pics
I've got about 3.5"-4" above my head but I am relatively short at 5'8". Now that the family is back in town progress has slowed, I've got seat mounts done on one side and working on the other. Next is going to be gussets, grab handles, and the harness mounts which I'm still trying to decide on considering I want to access the back seat still. I was thinking I may try to rig up a vertical bar with 2 or 3 tabs so I can adjust the harness to suit the driver and passenger although I'm sure it wouldn't be changed often except maybe for wheeling trips. We'll see what I come up with, gotta get it going soon though so I can make up some miles for the last few years it's been sitting around
