Pitman arms
  • Pitman arms
    Will a f150 arm fit the bronco box? I have a fw 44 up front and would prefer to stay with TRE.
    75 sport 302 c4 full width 44 front 9 rear let the building begin
    Re: Pitman arms
    I think so! I believe the stock EB pitman fits the 4x4x2 box so it should work the other way around.
      Re: Pitman arms
      Might depend on the year or the model, but in my experience "MOST" Ford boxes used the same spline and taper, so that pitman arms cross between multiple boxes.
      The differences are:
      1. Angle of the dangle. (drop)
      2. Angle of the other dangle. (pitch)
      3. Tapered hole size for the rod end.
      4. Length of reach.
      But they all seem to fit. At least from '66 Broncos to '96 Broncos/F150's. Probably the same for the cars.
      Some are just better fit for an EB than others.
      Paul
      Wild Horses 4-Wheel Drive
