Will a f150 arm fit the bronco box? I have a fw 44 up front and would prefer to stay with TRE.
Pitman arms
Re: Pitman arms
Might depend on the year or the model, but in my experience "MOST" Ford boxes used the same spline and taper, so that pitman arms cross between multiple boxes.
The differences are:
1. Angle of the dangle. (drop)
2. Angle of the other dangle. (pitch)
3. Tapered hole size for the rod end.
4. Length of reach.
But they all seem to fit. At least from '66 Broncos to '96 Broncos/F150's. Probably the same for the cars.
Some are just better fit for an EB than others.
PaulWild Horses 4-Wheel Drive
www.wildhorses4x4.com
71 U15 3.5" WH lift, Hanson rear, cut w/33" Swamper Thornbirds
68 U15 2.5" WH lift, Hanson front, uncut w/31 BFG Explorer engine/trans
