Looking down at the box what hole is the in let and outlet hole they sit side by side left to right .right one sits up alittle higher then left hole
power steering ?
Re: power steering ?
Can you post a picture? I run a stock saginaw Early Bronco power steering box and both ports sit level to one another on top of the box. The pressure port is the one that is closest to the front of the vehicle, the return is closer to the rear of the vehicle. They're both tapped into the same flat spot on top of the box kind of diagonal from each-other. There is no "higher or lower".
I am very curious to figure out what you have since it bolts into the factory holes yet your description of the ports is different.
Reference my build thread to compare to yours: http://www.norcalbroncos.com/forum/s...t=1297&page=60. Specifically, post 8931970 Bronco
That's what I have I just worded it wrong .its how u decribe it . So the pressure port goes into the pump and the other one into the resvoire I'm running a97 explorer set up has de.tached reservoirLast edited by old69bronco; 08-06-2012, 09:10 PM.
