are you still looking for a drop pitman arm I think I have one sitting somewere
let me know
yeah.. will pitman arms from Eb's, 4x2 boxes fit the 78/79 f-150 box?? I'll try to pull the stock one off my 4x2 box just too see.. But that wont be till later tonight..
Yes they should be the same! I test fit the stock pitman arm from my manual steering box on the my new 4x4x2 box and fits perfect. I carry it for a spare!
Anybody know what lines to get? will the 78/78 bronco lines fit the Sagnaw box? Does anyone remember what application they got their lines from? Shit Maybe I should just start the Hydroboost next and have the lines made once!! Thanks
Aaron the pitman arm should be at your house Fri. UPS Tracking #
1z950x350359551021 If you are going to a TRO soon why don't you just ship it back when done with it. that way it will still be around for someone eles that need one?
Brian
Brian
You got it!! OR... Maybe we could get a group run to Cow Moutain..
yea I have been thinging abought that but it is getting late in the season 6" of rain will close the hill till it drys out (48 hr no rain), so after Nov. its hit & miss. But I would like to host a run up there someday get the local Bronco guys up there too.Do an overnighter BIG BBQ Maybe even a few Jeeps
Well got the power steering hose.. Rush home to put it on.. After awhile of fighting with the fitting on the box side .. Finally got it on.. Everything looks good. Went for a test drive and the pump whines like a cat.. ADDED more fluid and the whine go's away..
Seem's to have a small leak around the adapter and the hose at the pump end.. So I grab a 3/4 wrench and tighten things up a bit.. WELL... the adapter is brass and STRIPPS.. WTF!! Oil everywear... DAMN DAMN.. Off to Lowes tomorrow to find another adapter.. What a waste of a afternoon..
One trip around the block felt good!!
next time HOLD A 5/8 on the adapter while you tighten the Hose!!
Hope this helps someone else doing the swap..
Ooops. Live and learn I guess huh? Did you bleed all of the air out of the system before you took it for a drive? That's hard on your pump to run it with air in the system.
