Thought id throw a little tech in over here it might help it might not. i posted this up on pirate but after helping a friend build his bronco front end the other night and installing the 8.9" JK D44 R&P (that he picked up as takeouts used for $50) in there i realized that sometimes passing on the info via reposting helps get out a sometimes worth considering upgrade. Even he said he'd wished he'd known of this option earlier since he'd poped a R&P just last summer. since im a stingy and stuck up ass of a jeep lurker..... or so everyone says firgured id try and break out and offer something up.
for the crowd that builds a F250 HP dana 44 some of this info will help still since a dana 50 jana 54 combo can be run / built for that also. Check towards the end of my top 5 posts here for a link to more info on the 50 R&P install
The 608.9
My Front 60/44 hybrid + some build begins:
Heres my bonified full on polished turd for a front end.
this seperates it for those looking for info on a something a little stronger than your typical 60/44 hybrid build as well if you have a 44 front end and just want to beef up your R&P to be a little more equal to that of your alloy shafts and joints.
in the stock LP 44 the 8.9" jk gears get you a little more fudge factor with ctms and alloy shafts pushing 37's+ now you can, your ball joints become the weak link.
wasnt sure what to call it there is nothing that rolls off the tongue like 609, or 60/44....but its not entirely a 60/44 hybrid its more imho with a jk44 R&P which is a different animal in many regards with the d60 sized pinion shaft, larger ring gear and deeper cut gears it deserves a little more consideration.
So Im going to call it a 608.9 since its a hybrid running a ring gear is 8.9" and its being matched to D60 outer parts
For my application i needed a low pinion front end so alot of this is centered around a lp front end build up, im doing a low slung sua build on my old cj and wanted a lp sua housing that would fit that part while looking clean and somewhat deceeiving.
I was eyeballing a 609 but for the money and parts that i already have this seemed like a fun alternative to try and build. My .02 is the RD147 is a little bigger than the RD99 air locker and they both have 35 spline side gears but the pocket bearing forces the RD99 case to be smaller but only marginally so. the dana 44 locker and the pinion offset of the D44 was a little better than the 9" for my passenger side front low pinion application .........the hypoid on the 9" is better for more tooth engagement and stength but the new cut on the jk gears seem to make up for alot of the old school dana 44's short comings in the pinion department.
Anyways I already have dana 44 housing so cost wise its a wash until you add the additional cost of a custom 9" housing and a high strength low pinion drop out, pinion supoport/skid.......
So this is the way the parts went together:
So dug I up a J20 Dana 44 front housing (3" tubes with 1/2" walls) and low pinion
(YES I WANTED LOW PINION)
Picked up a new 4.88 JK Dana 44 8.9" ring in pinion (maybe not a ford 9" ring and pinion but close enough and a heck of an improvement over a 8.5" lp D44) and install kit. through Carl with Jana enterprises
I picked up a front dana 61 for cheap to steal most my parts from
Welded on the D61 king pin C's
chased down A 35 spline dana 44 ARB 3 series or also called a high speed carrier
Set it up so the short side shaft out of a chevy D60 can always be ordered or used and made the long side shaft the custom unit.
Axle seal for the 3" x 1/2" wall D44 tubes to 35 spline shafts is Napa #15292 its a double lip seal
did a little bit of shaving (grinding) to the bottom of the 44 housing
clearance is good and strength has been great with a built amc 401, 133:1 gearing and sticky 37's on BL's
Somewhere on the internet a list of Dana R&P momentary load strengths appeared and between it and wikpedia it appears to be a means of measuring R&P strength in dana axles and keeps being reused. so i'll requote it
What you are gaining:
Pinion shaft diameter: 1.375" (most dana 44 & dana 50's) 1.625" (JK and nissan dana 44's same as a dana 60)
Pinion shaft splines and spline diameter: 26/1.12" (most dana 44's post 1970), 24/1.25" (JK & Nissan similar to the dana 60 29 spline 1.25")
The Dana Spicer Max momentary output torque FT-lbs
Low pinion Dana 44 8.5"............3460 [ft/lbs]
High pinion Dana 44 8.5" ...........4170 [ft/lbs]
Low pinion rear 8.9" Dana 44........5340 [ft/lbs]
High pinion front dana 50 9.0"...5000
Low pinion D60 30sp........9.75............... 5500
D60 HD 35 sp...9.75...............6000
i assume the difference in the JK vs the dana 50 is in the front vs rear application and the diameter of the pinion shaft but i can not voutch for exactly how they calculate this. what i can see is a significant jump in strength and size froma std low pinion dana 44 to either the JK gear set or the dana 50 gear set when used in a front end application
Obviously everything i did here was for the fun of overbuilding a dana 44 front end but parts and pieces can be taken to help you beef up what you have if you arent really front 60 material and are in to incrimental building of your rig
The 608.9
