After looking at my 92 ball joint Dana 60, the track bar would seem to be directly over my F100 power steering box pitman arm. I mean that when I set the 60 up with a track bar, centering it, the tie rod and drag link from the pitman arm will be directly over each other, thus hitting each other if the suspension cycled. Any other full width guys have this issue, did you go with the 4x4x2 box? I guess I could install bump stops and keep my box. Im a few months out of welding the track bar bracket on the 60 and still need to get the radius arms dialed in.
Just questioning my steering after the set up
Thanks
Thanks
