what is this,and were does it go
  • what is this,and were does it go
    I found this BOLT in parts drawer,not sure if it is to the bronco or not it has aqua green overspray so.......I have no clues , not missing anything anywhere
    Re: what is this,and were does it go
    Looks like a pivot bolt of some sort or a seat belt bolt.
      Shoulder bolt... Most likely from a pivot for some type of linkage...(clutch, transfercase....?)
        Is that a bolt from the BC saddle that welds to your tie rod and connects the drag link?
          I say T shift Transfercase linkage bolt like Efibroncoman
            X2 - I have a Shoulder Bolt just like it. Sometimes also used in aftermarket Twin Shifts to mount both sticks to a common shaft.
              Looks to me like one of the four bolts that hold the clear plastic cover on the flux capasitor! it makes time travel possible!
              Leave No One Behind
              KK6AUW
                If it wasn't the shoulder bolt for the T case shifter it would definatley be the Flux Capacitor bolt...
                  DAMN.....Thats why my Flux Capacitor STOPPED WORKING!!!!!!!!
                    I need that sign for my garage! Where? Where?
                    Leave No One Behind
                    KK6AUW
                      X2!!!!!
                        My flux is incapacitated right now,but would it have gone to the hand throttle linkage that is no longer being used or maybe clutch .No diag.shows this bolt to go off so i'll keep it till next week when install of power train,and see if something is missing
                          That is definitely a shoulder bolt for the rotoforda-stat.
                          No, actually it looks exactly like a transfer case shifter pivot.
                          1972 w/Explorer package
                          5.0L Explorer EFI motor w/GT40P heads
                          M5R2 5 speed trans/NP205 t-case
                            I think it is the canooty valve bolt that holds the fornortener rod together??
                              I would agree it looks like transfer case pivot bolt.
